evenin’ all curious if any one tried the ENO Streaming System Ag
looks an interesting product and has piqued my interest after watching the The Hans Beekhuyzen Channel review of it
i currently run a ER with MCRU LPS so curious if any one first has the ENO filter and how they found it and also whether the run it with a switch ER/EE/etc
You have already the Etheregen/ MCRU ps and Innuos Phoenix usb. I feel sometimes more is less.
If you really want to upgrade, go instead for the Innuos PhoenixNet or Music Works Ultra powerblock.
Or better Ethernet cables.
Other here have the ENO, as @BSMARK or Nemo. But they don’t have your system and switch.
I had the Acoustic revive lan isolator in the past. Worked fine until I get a Cisco 2960 and Audioquest Diamond Ethernet cables. It did nothing then.
As FR noted, I have the ENO AG filter. I do run it off an EE switch and am very satisfied with what I perceive to be a significant improvement in sound. But each system is different. I run it between my Nova (with a 250DR) and my EE switch and stream using a Roon Nucleus+. I use an ENO Ethernet cable to the Nova and a Luna - Orange Ethernet Cable from switch to Roon Nucleus.
Thx guys will plan a demo as you suggest now feels like a maybe cleaner option than adding a second ER in my network chain now which I was also pondering upon
seen they do return offer for 30days and seem to have good reviews on their site
The one I went with was: AfterDark OCXO 10Mhz Reference QUEEN MASTER CLOCK for U…
It was just under $600 US. Took about a month to get it. Plugged in in and let it burn in for a month or so, just got busy and did not want to dig into things to add it. When I did, it was maybe more burned in than most, but it was not under load, so who knows. Very pleased with it. May upgrade to the Phoenix/NET as a further step, based on the experience of several users on the forum–but could easily ride into the sunset with what I have.
Thanks Nemo, I would not have thought it could give you a benefit as you have already the PhoenixNet.
Which Ethernet cables do you use? My audioquest diamond have a noise cancellation inbuilt system already.
Yes, I use one together with their streaming cable and think it is very good.
That said, how much differnce will it make in a chain, as @frenchrooster points out?
You can borrow one and find out. The problem is that IF you do find it is additive you will have weakend my position that having this there is no point in adding more!
