This is the @HungryHalibut guide to success with Fraim:
The key thing with Fraim is to get the base level. Once that’s done, everything falls into place.
Tighten up all the metal parts on both sections of the base using the spanner, not really, really tight, but quite tight. That’s vague I know!
With the shelves, tighten the sharp cones as hard as you can with just your fingers, then add 1/8 of a turn with the tommy bar.
Make absolutely certain that the spikes don’t touch the edge of the cones. Polish the balls on your shirt before placing them in the cups. Then place the glass on the balls. If you have it the right way up it will ring slightly. If it’s the wrong way up, it will be more of a dull ‘boink’ sound.
Get the front of the glass lined up with the front edge of the wooden shelf.
The shelves will come with little circular disks that you can stick to the glass, to stop it getting knocked off. My advice is to put these in the bin - they look awful, and it’s almost impossible to position them to that they don’t touch the balls. Unless you are terminally hamfisted, or keep horses indoors, you have no need of them.
Now, after three months, the metal legs will have eaten into the wood, and everything will be loose. Take it all apart and tighten it up. After six months, do it again. After that it should stay OK - you just need to check the tightness when you do the annual strip down.
When you plug things in - especially the powerline - hold the front of the boxes - otherwise there is a big crash as the shelf slides forward and the balls roll across the floor. You’ll tell that I have been there!
The other thing is to add each box as you build, and make all the connections as you go. Sliding heavy boxes onto glass shelves reasting on balls is almost impossible!
Then get a flat duster on a stick for the weekly clean. Fraim, especially in black, is a total nightmare to keep clean. It will sound great, but it’s high maintenance…
