As of start of August the BBC discontinued Ondemand content on third party devices. We had implemented it in the new service, but had to drop it.
We do however support Chromecast, Airplay2 and if really thin on options, Bluetooth from BBC Sounds so the content from that app can be played on the products.
A few years back (might of been more - time wizzes along), we did look at this but very few customers were using it and it was hard to justify as a business case. With more customers moving to using premium streaming services the days of these type of apps that are focused around music library management is becoming more niche.
We’ll re-review though as sometimes things change and they’re on to something good.
Ok in the presets but do not function when I select it coming from a Tidal tune or another radio. I have to select the preset two or three times before it works !!
The update works well on my Atom but I have to turn up the volume to reach the same noise level as before. Are there any other people who are sensing this?
Thx for your answer but what exactly do you mean with “Input Trim”?
I have since discovered that increasing the Max. Volume in the system settings has an effect; for me it is now set to 66% as a precaution to protect the speakers from inadvertently twisting the volume knob
Yes, when maximum volume is set below 100(%), the current volume is in relation to this (and not capped below 100 at the value set for max), and still from 0-100.
So, when say maximum is at 50/100 (enough for me), and current volume is at 50/100, you’ll in total have (about) 25/100 of maximum output volume.
(Not considering the input adjustments just mentioned above.)
My Uniti Nova has been working flawlessy until the latest update. Now it unfortunately does’nt work well. There are constant interruptions when I use Qobuz. Very boring! What to do? @Stevesky@Richard.Dane Also have an NSS 333 and two Mu-so Qb 2nd generation. It seems safest to refrain from updating these?!
I do find this interesting. I saw something like this with Qobuz when I updated. A track played but it dropped out. I tried it again and it was fine but I did restart my streamer for good measure.
Everything is fine now. Maybe a network route or cache to Qobuz servers had been updated.
