Thats actually a great idea. I see that the 4200 has XLR connections and therefore you could use standard balanced xlr cables?
I still want to pair my Naim AV2 with a Linn AV 5125
I have the unbalanced Akurate 4200 so I have to use RCA cables. But I’m very satisfied with the sound. The pre amp in the Atom HE is excellent!
I’ve it now connected to my Nap 200 via a 5 meter long rca to din-4 cable. Its a signal only cable I got made years back by Flashback for my AV2 and does good temporary service now.
I’ve a 2*xlr - din4 cable on order - special build.
Ultimately I’d like to pair the Atom HE with a CB Nap 250 - I think that looks great together.
I’m sure it will be awesome
Hi all.
Am I right in thinking the balance control setting is not active when listening on headphones? Just curious!!
just wondering. does anyone use the Atom HE as a streaming source into a Supernait 3?
Looking to move up from a Node2I and the screen/form are ideal for my set up. I’m not currently a big headphone listener but that will probably change.
Was also looking at an Altair from Auralic but would prefer to stick with Naim if SQ was good
I had Chord make me a DIN to XLR cable so I could connect my Atom HE to a NAP 250 DR. It sounds great.
I was using my HE primarily for headphones but since I tried the Atom HE/250 combo, that’s all I listen to.
I’m so pleased with this two box system, I’m going to sell my 500 system.
I can vouch for the Atom HE as a streamer/DAC. It’s also a great headphone amp.
You could replace your SN3 with a 250 DR. You’ll have a better amp.
Im in a similar situation. Ive used Atom HE for headphones only so far. In the loft Focal Aria 906 K2 are run by Melco-Dac- SN3. I wonder if I should run the Arias with HE, poweramp instead, and sell SN3. That said, I find 250DR a bit over the top in my case and are looking for alternatives right now.
S
There was an error in my response to the question about using an Atom HE as a streamer. The cable I had Chord make was a 2RCA to XLR.
Wow, that is quite a statement! Nice. ![]()
How close is the HE/250 to the full 500 system? Sounds like a veritable bargain and great 2 box solution.
First of all, it’s far more user friendly than my big system. The digital volume control has more granularity, it’s safer because you can set max volume, I can control all of it from my iMac, the remote does everything and is backlit. It doesn’t require line-of-sight operation.
It’s far more forgiving than my big system. I can put together a huge playlist with Roon and with my big system I’m constantly skipping tracks or changing volume. With the Atom HE I just sit down and enjoy the music and almost never have to do anything. I find myself singing out loud and beating time with the music.
I have no idea how bass would perform on bigger speakers because I’m not into bass. The NAP 250 DR should be capable of good bass reproduction.
I have Harbeth 30.2’s in a small apartment. I never play very loud and I almost never listen to music recommended by Tidal.
I’ve tried fronting the Atom HE from my ND555 by connecting it with a pair of RCA’s. If there is any difference, it isn’t much. Of course it may be masked because the HE converts analog to digital and then back again.
I don’t believe in free lunches so in a different space, different speakers and with different music my 2-box system might be a big disappointment. For me in my space, with my speakers and at my age and tastes it is extremely satisfying to me.
I don’t need the money so I don’t need to sell the big system. It was just a matter of that expensive resource sitting there unused.
The cost of the HE, a used 250 DR and a Chord cable was less than $10K. The Ansuz D2 DIN/DIN cable I use to connect the ND555 to the NAC 552 cost more than I’ve spent on the 2-box system.
I am keeping some expensive Ansuz ethernet cables and an Ansuz Power Switch along with Ansuz power components. So others may not experience what I’ve experienced.
Not sure if my Naim HE just died. I was listening to music thru roon and it suddenly stopped. The Naim HE screen was black and the remote and front buttons didn’t respond. I tired unplugging for 2 minutes and nothing happens when plugged back in. Holding power button and play/ input do nothing. Naim app can’t find it either.
Any suggestions? Was going to leave it unplugged for a while. Nothing else in house had issues and tested outlet and still has power.
Hell, that doesn’t sound good. Hope it’s ok.
Is it a fuse in the plug ? Have you tried changing it or using another power lead ?
I would check the fuse by the IEC inlet. Hopefully there’s a spare in there, but otherwise I would contact your dealer first thing.
How do you open to change fuse? New power cord didn’t work.
In my search I saw you posted in the past to never change fuse yourself. Is that the policy of Naim. If fuse blows under warranty to send back to dealer? If it’s something I can do, I’d rather not send back and waist the time.
Never try to change for an “uprated” fuse. However, changing like for like is fine. Always ensure it is EXACTLY the same - same type, same rating. Even same make is a good idea for many items (XPS2).
The fuse holder is next to the IEC inlet on the back of the Atom.
The OP has clearly never owned an xpsdr!
Ah thanks. So I’ll open and check for a spare, otherwise order some extra ones. It list the fuse type on the cover.
