Oh no!
“Yes” !!!
Rear ported needs the rear wall to get the manufacturers freq response curve…
(the book will have guidelines for a minimum recommended distance)
My ‘guess’ regarding damping the direct route out (to the wall) is that you may have had ‘such a tight bass’ that it was ‘feelable’ but not ‘hearable’… and the more we break up those waves the more ‘hearable it becomes’…
Just speculation
I feel at this point it is time to ‘get the string out’ (and a mirror)…
and do the due dilligence- use the mirror on the side walls, and ‘from the listening position’, take not of where you ‘see’ the drivers; this is ‘direct pathways for your second reflections’.
It is possible to measure the length of that pathway and figure out ‘how long’ (time) between direct sound and reflected sound.
Our brain needs’ a minimum amount of time to be able to ‘process’ that there is a gap and actually make use of ‘the room’.
I’d also encourage some bass (frequency) sweep (tones) and listen for ‘gear changes’ or a ‘lack of smoothness’, and move speakers to get the frequency response (low) as ‘smooth as possible’. (by positioning from the rear wall and 'with dampening materials).
The toe in doesn’t alter the rear porting ‘distance’ too much, so sorting one, and then the other, and ‘then a slight adjustment’ (front /back movement) to readjust the bass frequency to ‘what you had’ should allow a 'best of both worlds.
30cm (a foot) is the minimum for our ears to discern a time difference,… but 1 metre is normal zone,… (not quoting any reference material here, and I welcome any placement experts to come in a trump this info, especially with their favourite chewyyoube links to further this discussion)…
not trying to be an expert, just get the ball rolling…
using the above guide… the length of string measurement bouncing via the side wall and direct,… will have a measurable difference… factoring the ‘speed of sound’ that allows you to figure out the ‘timing’ that those second reflections are delayed.
(you can vary that length by moving the speakers closer/further to the side walls), which, when also factoring what is needed for bass, might come up with an ‘odd placement’ to consider for the speakers to be… (but maybe ‘try it’)…
using familiar test tracks might get you so far… (with regards to soundscape, yes, but with regards to bass delivery, may not cover enough spread to fully know ‘what is going on’).
I must admit I have’cheated’ a few times…
I ‘borrow’ the surround amp from the theatre room and use it generating a graph on a screen to ‘see’ what is going on with the bass frequencies,… and then I move the speakers until I get pretty dam close to flat line sound,… (And then I take the processor back out of my ‘den’ setup).
