Thank you… it’s a very nice lamp… good taste you have !
Pic from hatton website
That is a lovely light Nigel - really works in that space
I wouldn’t have had the guts to get it without your suggestion. It’s much easier to get a conservative looking lamp. I was nervous it may look OTT but it’s absolutely fine.
Looks good, Nigel. The new lamp finishes things off very nicely. I suspect that we’ll be purchasing a few more BTC lamps in future.
Thanks James. Best get saving.
That’ll be better for reading in that chair too than with a table lamp. However, I did prefer the look of the table lamp.
The lamp equivalent of Naim’s latest firmware, clearly.
I’m not sure there’s much clear about the latest firmware, although I haven’t been aware of the harshness some are reporting, despite using two power supplies. But then I don’t use any exotic ethernet cables.
Very nice @HungryHalibut On the subject of lamps this is my ‘cheapo’ version from John Lewis. This is my dining room “gentleman’s chair!”, mainly used for classical music listening from the Muso.
Following a full clean of the Conservatory this morning, just finished putting everything back and reconnecting stuff.
Had a bit of a shuffle with general bric-a-brac in Mrs Q’s absence…
Switch in locale, moved to the cabin…
Aren’t the speaker stands too high?
Feet porn!
Didn’t Bagpuss want to come along with you?
ATB, J
They’re on top of the speakers to stop Luna jumping up on the tops of them. She is somewhat indiscriminate in the use of claws when jumping up onto them🙄
In respect to what?
The stands look very high in the picture.
They stand a bit higher than normal because of the Gaia’s I guess, but they are at the correct height for my listening position so they are not too high for me.
If the height is around 1.1 m -1-2 m , it should be ok …cos the listening position is quite a distance away ?
It is exactly 1m from the floor level to the bottom of the tweeter, which is about bang on for my ear level.
