Roon 1.7 is certainly not as bad as that for me. The problem I have described above for the time being is the only one I have found.
The problem persists today. I rebooted my NUC this morning before starting a Roon Radio session using the Artist ‘Govi’. The first couple of tracks were ok, but once again got a blank ‘track details’ screen with the 3rd Roon track selection.
I subscribe to Tidal, not Qobuz. Perhaps there are more problems with Qobuz integration?
Later last night Roon support suggested I log out of my Qobuz account from Roon and log back in. I did that and played another full album without any skipping issues. Hopefully that solved it. I’ll play it more later on today and see if it’s resolved.
Not as far as I can tell - I think Roon’s error was to try to amalgamate purchased items available to stream with items in your library, so duplication would almost be inevitable - far better in my view just to show you local files in your library.
Since I took the suggestion from Roon support to log out of Qobuz and log back in, it has been working better. No skipped tracks since. In retrospect I might have been a bit harsh.
I am on an older build which shows my Qobuz purchases - despite having the option not to install updates automatically Roon constantly tries to download 1.7 - I don’t want it to and will be rather annoyed if I’m stuck with 1.7 onwards.
Restoring Roon from Time Capsule on Mac does not seem to help, perhaps I need to update then revert?
It will always remind you as with no updates your using unsupported software and are on your own. On Roon core go to settings , then about you should see your core logged and this should have a great icon where you can tell it how to update or not to.
I set it not to update automatically ages ago, but it keeps trying to download 1.7 - I can’t quite remember if Roon downloads but asks whether to install 1.7 or not, or just proceeds to do so and restarts or simply installs on a restart.
Thanks - I’m not sure if you’re suggesting Qobuz purchases are back under a My Qobuz type section or if you mean they are now automatically added to your library in 1.7 which is why I thought the feature I want was removed in the last version prior to 1.7 (and the reason why I have been using the one prior to that) as it confused people .
