IMPORTANT: Please note that if you use Roon Remote on iOS or Android devices, those apps will need to be updated in order to be compatible with a Roon 1.8 Core. We suggest that you update your iOS and Android apps before updating your Core.
I donât think thereâs going to be a precise time, given weâre advised to update our control apps first. So when I can see the roon update available in the UK Apple App Store, I can update my iPhone and iPad. Then check using the app to see if roon core itself will update, plus same for roon bridge.
What about roon in the streamers, do these ever update? I assume this is similar to roon bridge software but have no idea if this follows any code release/update cycle from roon. [edit] this would be a firmware release from Naim to incorporate an update to the roon raat sdk but doesnât seem to happen much. Just read on roon labs forum.
Apparently just the app and the Core need to be updated. Roon Ready streamers stay Roon Ready. Over on the Roon Community they are predicting normal Core update release times of around 9am Eastern Standard Time but the app (which has to be installed first) is released internationally by Apple & Co. at different times.
Agree. And bearing in mind what we spend on the hardware and streaming services (not to mention CDs etc) the cost is reasonable. Roonâs algorithms which predict what you donât know but may like has introduced me to music I wouldnât have come across without it
Depends. You canât expect the thread to recommend an obscure Austrian 80ies punk band based on having listened to another obscure Austrian band. Not everyone is from the UK or US.
Well yes it does, but the Roon recommendations can still be useful, is my point.
Anyways, personally I donât have a problem finding new music, my problem is proper management of the huge number of music I found in the past and am finding continuously. And Roon is the best solution I have found for that
It should for the core, the US east cost guys are in the office now, dunno where Roonlabs is located.
But for the apps, we are at the mercy of Apple/Google, and remember that you should update the apps before the core
âNote that this application is only designed to work with Roon Essentials hardwaare such as the ELAC discovery. This application is not compatible with Roonâ
From the details page in the Android store. I have no idea what this means but does not seem Iâd need it
