System Pics 2022
And a rather cute Pro-Ject turntable as well…
Like Clearaudio a brand somewhat neglected on these pages
Nice. What about these huge cable lifters?
Repainting of the room where I listen to music … :scream:
For a moment, I wondered whether it was still Lent… :wink:
:joy::joy::+1::+1:
Sehring speakers, aren’t they? I’ve ownership a couple of S701’s many years ago … very good speakers. Die to a house move, I did not had the space to set them up properly hence I’ve moved away from them
707 in partial sun.
Aavik I-280 replaced Audionet SAM. Adjusted my box order and cable dressing as well: left side: NDX2, right side: XPS DR.
Giving the MK2 Gurus a run out replacing the Mk1’s.
Sounding very good on the Audiolab juiced system, which also seems to have resulted in an improvement in the sound from the Yam streamer even though it’s not directly connected to it.
Apollo transport, MF Dac and Densen pre / power all on their dedicated DC Blocks now.
Thanks. The cable lifters are there predominantly for tidiness and to allow the Roomba to pass underneath :slight_smile: I didn’t try if it makes an audible difference nor do I care too much, but it feels good to have done what I can.
These ones you see in the pictures above are two door stoppers on top of each other. There are also foam yoga blocks behind the TV furniture to lift the cables there. You can find more details of my frankly impressive :wink: cable management in an older post, link below. I’ve cleaned it up a bit more since then.
NACA5 stiffness is perfect for this
Yes, the new Sehring S913, they are fantastic. Interesting you also know of them and even owned some, we are a small and exclusive club :wink: The Sehring factory is just a few minutes from me by bike and Stefan Sehring is a great guy. I’ve had them for 6 months and loving them.
Pics from setup:
Been moving the KC-62 about and some slight tweaks on the Meta positioning, sounding super tight now.
Loving the MusicCast function to link streamers together, Thom Yorke now simultaneously playing in cabin and main listening room and chilling in the garden.
ATC SCM40 in the evening sunlight.
Um, I know I’m new, but . . . did you all skip the page in every owner’s manual that says “avoid direct sunlight”?
We are not living in caves, lantern :slight_smile: and indeed who reads manuals these days.
All it can do is change the veneer or paint a bit, not going to live in a bunker to avoid it :man_shrugging:
All speakers benefit from some vitamin D. :wink:
They look ‘grooved’ , Groovy speakers?
Sunlight showing up dust and tatty foam. I dusted on Sunday believe it or not. :persevering_face:
Recognise that. Hifi systems are dust magnets. I try to keep up dusting the lot biweekly. :woozy_face:
