Thanks all. Not sure if I have extra long burndy cables but they’ll definitely touch the floor if I move the amp down. Is it possible to tie them in a bow to lift them up a bit?
The Burndy cables will all be the same length. It is possible to put a light twist in the cable without compromising the “de-stressed” state around the cable connector interface.
My how your stack has grown (and evolved) over the past few years. You must be in a very happy place.
Cheers @Pete_the_painter, yes very happy with it all. I’ve been very fortunate with pre-loved opportunities, ending up higher up the range than was ever hoped for. I’m pretty much set on the Naim kit now.
Extension all but finished bar carpets and curtains. Sort of quite liking the industrial underlay look.
Need to rebuild system in a few weeks when carpets arrive - will ‘cable dress’ and spike the speakers then.
The ATCs and NC250 are fresh out the box and have an hour on them both. The Technics SL100 was a Costco Black Friday special!
The ATCs sound incredible; and the Technics does a fine job with my old dance vinyl!
Wow volume at 11 o clock. They for sure need a bit of welly then the ATCs ![]()
I’m guessing bit low output signal from the phono
I liked the digital input trim ability on my former 272. I believe that’s available in the new classic series too.
282 less than a year old - it’s going nowhere. Was my ‘aspirational’ bit of kit for ages!
. Your cat is really making a Statement. ![]()
I have active ATC’s - they really are a great speaker and huge value for money too compared to the usual suspects. Enjoy!
They certainly win on VFM compared to other brands if measured purely on weight!!!
It’s amazing how the music is portrayed differently.
Is it possible to describe the differences?? I have an Aro and I am used to what I am used to. Not heard anything different in years.
Tired of a big cardboard box in the living room. So I installed the Danish turntable into its new? home. Will have a leveling platform made before I start to play records. I love the design.
I will also have a new rack made out of black valcromat that will be waxed and polished. Gives a nice finish.
It is a mess right now and are work in progress…
Love the Heritage Specials, I used to have a pair and can still remember how mesmerizing they were after S40s which are also amazing in their own right. I also put them on marble squares similar to yours (maybe concrete? ).
I can only imagine how those sing with that rack full of separates.
Beautiful system.
Caught in the middle of an upgraditis here. They are getting along exceptionally well with the New Classic spread. Still waiting for the new speaker cables to arrive for the new baseline SQ.
That bottom photograph of your system looks very neat and tidy. Excellent. That ‘picture’ in the middle is that one of those Samsung picture TV frames?
Thanks Marty. Yes they sound so right. I can listen to them for hours! The bases that the HS’ sit on are off cuts of a silestone worktop that I had cut for me at our local marble supplier. I see from your subsequent pictures that you moved on to some mega Dynaudio floorstanders which I’m sure sound very impressive.
Thank you ![]()
That is indeed one of the Samsung Frame TV, not the greatest picture quality but it was a good fix for having to put the TV between speakers due to the layout. That cable though, I need to make that disappear at some point. Messing with my OCD ![]()
I completely agree with your assessment, I know their sound and they do sound so right. Especially with your Naim stack. I also noticed you added the Isoacoustics isolators under. What was the effect after adding them? I bought a set as well but waiting for the right stud size.
I call the new floorstanders Great Danes since they are so tall compared to the standmounts that I’m used to. Once they broke in, I got a pair of Shunyata Delta power cables for the 250 and 300, and the system sounds pretty impressive so far. Now waiting for the upgrade from Venom-X speaker cables to the new Delta speaker cables. I just think there’s something special about that DDC waveguide design with these and the added benefit of dedicated midrange driver.
