Since electricity prices are due to rise significantly soon I was wondering what the cost is to keep the system on at all times as recommended?
My system is 72/HiCap/250 a mix of CB and Olive. I have always kept it on except for holidays. In addition to the cost question I was also wondered if I was to leave the system off is there an ideal warm up time say 1 or 2 hours?
Iād highly recommend to fork out $15 for a wattmeter. Program in your price per KwH (Iād go for the mid point price between your on and off peak rate) and measure it yourself. Youāll have an exact answer for the bits you have.
Brilliant devices reveal a lot about what costs the real money to run in the house and what things you think are costing money are just nonsense myth. Spoiler alert, phone chargers etc, consume nothing when not charging your phone so unplugging from the mains saves you nothing.
In my experience, NAIM boxes take three days to warm up, but are ālistenableā on the first day, āmid-range vocal honkyā on the second and blissful after the third.
As ever. you pays your money and takes your choice.
Leaving it all on is an essential, afaik.
Take down the central heating a couple of notches and wear warm clothes indoorsā¦
If have a meter that will measure the power being drawn from the supply but it wonāt do the cost calculation for you, hereās how to do it:
Measure your systemās total power consumption in Watts (or preferably Volt-Amps, if your meter can distinguish between the two) with everything idle, and call this value P
Divide P by 1000 to convert it into kilowatts, call this value K
Multiply K by 8766 (the number of hours in a year) to find the number of kWh used keeping your system on but not playing music for a year
Multiply this by the price youāre paying for 1 kWh (using an average value if necessary, as @feeling_zen suggests)
For example, if your systemās idle power consumption were 30 Watts and youāre paying 20p per kWh, that would be Ā£52.60 per year, or just over 14p per day.
Do you have any electric heating or cooling? I did a recent exercise the same as you and when I got to the AC (which is the only heating we have in winter here too) and dryer the numbers were astronomical. The hifi and everything else was just a rounding error in comparison over the course of a year.
My hierarchy of consumption was definitely
80% heating/cooling
15% computers and monitors (both my wife and I work from home)
5% everything else
But I managed to tweak the dryer and AC settings to shave off over $100/month from the energy bill without any noticeable reduction in heat/cooling output. So the wattmeter paid for itself several times over after just one month.
No electrical heating, hence why I can concentrate on the low items using power. The biggest thing I found was the old inside freezer which I replaced when I realised how bad it was. It was picked up via freecycle by a lady whoās current freezer would freeze up too much, so overall not completely environmentally unfriendly. As you can see, that move alone saves Ā£90 a year.
My specific aim initially was to try and understand why the house was using >300Watts all night when we are asleep. Currently it now moves between 170 and 260, so happy with that, and feel better about leaving the HiFi on.
BTW, being in England means very few here have cooling facilities other than opening the windows, and cheap little noisy fans to spread the heat around
Left my system always on. XPSDR/CDX2,555PS/NDS,NAP300 and NAC252/SCDR. Power consumption some 80W,which amounts to some 700 KWh annualy. 20% of my electric consumption bill.
Anyway,as a test,powered everything off and only powered it on when I want to listen music. No audible difference,everything sounded just as sweet as when I left everything powered on. So now everything gets powered off after listening. Cut off 20% of my power bill. And no disadvantage. No brainer imho. But as always, YMMV.
Iād love to be able to turn mine off and not hear a difference. The sound is always a bit thin and anaemic when first turned on, so it stays on. I have my NDX2 set to go into standby, which of course you canāt do if using an external supply. As @Martinzero says, Naim must surely be working on ways to cut consumption. And if they are not, they should be. Itās not just the cost of course, but the impact on the planet.
That is alarming. Represents my monthly electricity bill just running your hifi for a year!
Presumably that includes listening time. What sort of duty cycle do you think your listening is? For me its a couple of hours in the evening about 8% listening timeā¦
I am of course assuming it draws more power when you are playing musicš
In my case, listening increased from an idle 56Watts to 75-95 Watts, so yes that is a higher cost, but that is only 1-3pence for a two hour session - well worth it in my opinion
Why not? I have my NDX2 go to standby with an external supply, it surely is possible, and if nothing draws power, the supply by itself shouldnāt, either (I guess).
(My reason for the standby is to make the screen turn off and I have server mode on to keep warmed up)
