I did that exact comparison a couple of weeks ago at a local dealers between the P10 and a Linn Akurate LP12 and my preference was the Akurate LP12. Of course the Akurate LP12 is about £2500 more but they are both in a very similar in price range.
I will definitely have a listen to the akurate before i decide always liked the look of the Linn
Happy Christmas
I would love to know what your preference is if you decide to do the comparison.
Happy Christmas to you too. All the best.
One other thing I picked up at the dealers was that Linn will shortly be bringing out three new upgrades for the LP12, so it will be interesting to see what they are.
Bugger!
It’s a NeverEnding Story!
Have you decided how to spend your 10 grand Cooky.
Happy New Year
Happy New Year!
My turntable is similar to Akurate level with Kore, Cirkus and modded Akito arm upgraded by Audio Origami. With a Lingo 1 and Graham Slee phono stage it sounds fantastic. Works well with Dynavector 10X5.
You could get a used LP12 with many upgrades at higher level than Akurate for £5k - £7k and have change to buy records.
There’s a fair bit of depreciation on the kit from new so good deals to be had!
I’d spend money on sources.
Im still playing with the dealers p10 he wanted some miles put on it,it is sounding very good right now after 6 days i shall return it next week and either bring the linn home or do a side by side comparison in the shop now i know the p10 so well.
Happy new year to all
well back from the dealers returned his p10 which set up alongside the linn akurate played half a dozen tracks through the p10 to get acclimatised then we switched over to the lp12
well the start of tears in heaven brought a tear to my eye neeedless to say ill be ordering the linn at the end of the month
The cartridges and phono were on the same level ?
linn krystal and apheta 3 both going into aria phono stage
Why you preferred the akurate? On what criteria ?
Keep the 52/135’s and spend the £10k on a high spec s/h LP12 and some LP’s
Bringing tears to his eyes, seems like it. That is about as flat earth as it gets.
The linn is nicer , I agree. But sound ? Specially on akurate level…humm…
I personally would not build an Akurate LP12 as currently defined by Linn, but I’m not surprised by the results TBH, though the cartridge used should have been the same.
The akurate lp12 costs 3 k more vs p10/ apheta 3. Add 3 k to the aria price, and you have p10/ apheta 3/ Aura. It would swallow the lp12 akurate aria.
That’s partly why those definitions are silly. Fit a better arm than the Akito (like an Ekos from a reputable dealer) and a Radikal instead of the Lingo 4 on the Akurate and you’d have a much better deck for about the same money.
As for phono stages, you can use them with either deck, so again I think it’s silly to think of them as part of a package.
I was only considering the 3k differences between both and what would sound similar prices set up.
