Naim Audio reveals the latest addition to its New Classic Product Range: the 300 Series - A New Era in Sound
Continuing our 50th anniversary year in style, Naim Audio is delighted to announce reference-level additions to our Classic range of hi-fi separates.
The exceptional new 300 Series includes the NSS 333 streamer, NAC 332 pre-amplifier. NAP 350 monoblock power amplifier, NVC TT phono stage and NPX TT power supply. Both the NSS 333 streamer and NAC 332 pre-amplifier can enjoy a performance boost by adding an NPX 300 power supply.
Designed and developed by Naim engineers in Salisbury, UK, the New Classic products are at the forefront of innovation and technology. Timeless, they are carefully crafted and built to last. Sophisticated yet simple to use, they will provide years of listening pleasure.
“The new 300 Series is Naim at its purest – pushing the boundaries of what’s possible, in service of the sound. With cutting-edge innovation, superb connectivity, bold styling and exceptional performance, we can’t wait for you to see and hear this amazing range.”
Steve Sells, Technical Director (Hardware) at Naim Audio
THE CLASSIC 300 SERIES IN MORE DETAIL
NSS 333 HIGH RESOLUTION MUSIC STREAMER
At the heart of every good hi-fi system lies a good source. The NSS 333 provides a high-resolution streaming solution which does exactly that, in its support of top-rate file formats from UPnP devices and streaming services. Using the NSS 333’s internal DAC enables improved performance from other audio devices within your system, benefitting from universal control across the Naim range; all operated from the intuitive Focal and Naim App.
• Latest Streaming Platform - Stream all your favourite radio stations and music from Spotify, Apple Music, Tidal and Qobuz.
• Easy playback from all your devices via Apple AirPlay 2, Chromecast built-in and top-quality Bluetooth.
• Works seamlessly with a range of other Naim streaming products, including Uniti and Mu-so systems. Choose the same song in beat-perfect sync or play different music in different rooms.
• Superlative build quality and beautiful design, built to last.
• Full colour high resolution 5.5-inch display.
• Place anywhere – Balanced outputs for retained quality over long distance and rack mounting installation.
• Excellent remote control connectivity – Zigbee allows non-line-of-sight bi-directional control.
• 0.5W Standby – reduced power consumption.
• Perfect partner for NAC 332 preamplifier and NAP 250 or NAP 350 power amplifiers.
• Upgrade performance further still by adding NPX 300 power supply.
NAC 332 HIGH-END ANALOGUE PRE-AMPLIFIER
Including numerous elements derived from Naim’s flagship Statement S1 pre-amp, the NAC 332 is the analogue source hub without compromise, delivering the best in musical performance to your amplifier and loudspeakers. It’s Naim’s most adaptable pre-amplifier to date, allowing the connection of headphones and the NVC TT phono stage for exceptional vinyl playback. Optimised circuit topology provides improved musical performance from all your sources, controlled via the convenient remote volume control and input selection using the Focal & Naim App.
• Dedicated preamplifier – less internal noise for optimal sound quality. • Superlative build quality and beautiful design, built to last.
• Built-in premium headphone amplifier (1.5W pure class A).
• Connect your turntable using the optional NVC TT phono stage.
• Connect other sources, such as your CD player.
• Closest preamplifier design to the Naim Statement (NAC S1).
• Superior components – through-hole components for higher quality performance.
• Place anywhere – Balanced outputs for retained quality over long distance and rack bay installation. • Excellent remote control connectivity – Zigbee allows non-line-of-sight bi-directional control.
• Combines perfectly with NSS 333 streamer and NAP 350 power amp.
NAP 350 REFERENCE MONO-BLOCK POWER AMPLIFIERS
This state-of-the-art 175W mono-block design offers tailored capability across a large range of loudspeaker options, from single to multiple amplifiers, and its internal cooling system allows for discrete placement within your chosen environment. High current delivery for dynamics - peaking at 1.7kW into low impedances – drives even the most demanding loudspeakers.
• State-of-the-art mono-block amplifier solution – each amp offering 175W with 1.7kW peaks. • Superlative build quality and beautiful design, built to last.
• Temperature-controlled fan for discrete placement.
• The solution for the most demanding loudspeakers.
• Best ever compatibility – true balanced XLR means easy connection.
• Versatile solution – from mono to multiple amplification solution (bi-amp, tri-amp etc). • Combines perfectly with NSS 333 streamer and NAC 332 preamplifier.
NVC TT & NPX TT REFERENCE MM/MC PHONO STAGE AND POWER SUPPLY
Enjoy your cherished vinyl collection like never before with this new Naim combination – an evolution of the Naim Solstice Special Edition phono stage and power supply pairing. The NVC TT is fully compatible with moving magnet and tailorable to your preferred moving coil cartridge. It easily connects to the NSC 222 and NAC 332 pre-amplifiers, offering the very best in elegant vinyl playback.
The NVC TT can be powered by the NSC 222 or NAC 332, or you can add the upgrade NPX TT power supply for peerless performance and wider connectivity options.
• Enjoy your cherished vinyl collection like never before.
• High quality Phono stage for connecting any record player you desire (moving magnet and moving coil cartridges compatible). • Simple connectivity to NSC 222 and NAC 332.
• Fully tailorable to your preferred moving coil cartridge: 16 selectable resistive values; 16 selectable capacitive values.
• Upgrade NPX TT power supply available.
NPX 300 POWER SUPPLY – THE INSTANT UPGRADE
Previously announced earlier this year with the 200 Series, this dedicated power supply provides an instant performance upgrade for a range of Naim Classic models, including the NSC 222 streaming pre-amplifier, NSS 333 streamer and NAC 332 pre-amplifier.
Further information on the NPX 300 Power Supply can be found here:
