Same for me…
I have the desire to buy the NC 250 . Don’t know when for now. But I wonder if the balanced cable will fit in my Ear 912 ? Normally, but I want to be sure.
Looks standard and should he absolutely fine? (the ones on the EAR look like very good quality btw)
Here is what the HE looks like and a standard XLR that connects it to the 250NC
Thanks for the link. That will be useful!
I must have picked up the same reference. I played this track in the demo room and their reaction was ‘oh, the hippo track’.
Who is going to get to him first, I wonder.
He’s already confirmed he will look at it tomorrow morning for me (he was coming anyway)
Looks like we’ve probably got this sorted already but I will confirm with most, couple digital copies as well as 3 different vinyl copies, all drums on the left.
So for the folks not hearing the instruments in the correct position, is it as simple as the channel/speaker connections getting reversed? Or is it more complicated than that?
Check with your dealer. IIRC some early units may possibly have gone out without a FW update so the balance is opposite. If that’s the issue then should be easily updated by your dealer.
I think it’s just the speaker cables connected the wrong way round. Just one of those things
You seem to have alighted on just about the most complex bit of the piece there. If I had the 332/300 combination wired up I think I’d be able to say straight off, but I can’t be sure listening to the 333/300.
Thanks. Will do.
Yup, or in the case of the 350 the connectors reversed. A simple fix is all that is needed.
Yes. Listening to it right now: drums, sax, bass, piano from left to right.
Gotcha, wasn’t sure since you needed to call your dealer. I assume you’re able to switch the connections.
Yes I can switch them but Pete is coming tomorrow anyway so he can fix his mistake
For clarification, could you please advise which version of the firmware contains the fix? Thanks in advance @Richard.Dane .
SORG hosting 300 series evening on the 29th Nov. Planning to get along
My go to album to check if the speaker cables are wired correctly is
Branford Marsalis: Trio Jeepy
First song the trumpet should come from the left speaker.
Great album by the way.
