Yes they are stunning.
The 350s are really rather good arenât they. @110dB and team have done a fantastic job here !
Tired eyes, now corrected, thanks Ian.
Indeed they (350) are stunning . l love the way they grip the speakers.
Not to nitpick or anything, but wouldnât source first dictate 332+300+250 beats 332+350?
btw: congrats on your system⌠very very nice ![]()
Perhaps choosing between the 250 or the 350s is speaker and room dependent? Maybe in a small room with easy to drive speakers the difference between the 250 and 350 may not be that great?
Iâve not heard the 350s (I didnât want to be tempted âŚ) so Iâm simply speculating.
Hi @tom-in-amsterdam, thanks for the reply. All I can suggest is that you do the comparison yourself - for me it was really obvious that the extra power of the monoblocks was better.
I just got.the 332 and am installing it on the fraim. Seems the rca inputs are just in front of the back leg of the fraim??? I cannot connect my rca cables without placing the amp way too forward on the shelf. This seems weird. Has someone found a solution?
The easiest thing to do is to slightly loosen off the rear leg of the Fraim and rotate it a little to facilitate the connection.
Naim are supposedly releasing a modified Fraim rear leg, standard height only, to resolve this issue.
ATB, J
Yes, if you can, place the pre-amp on top (usually sounds best there), otherwise, best rotate the leg 45 degrees and then contact your dealer to enquire after the new narrow Fraim leg when itâs available.
Thank you. I have a turntable on top so will use the other option. When should the skinny leg be available?
I donât know. Naim will let interested dealers know as soon as theyâre ready.
Source first does not dictate anything. There are a lot of factors at play.
Thereâs also the option of going RCA-DIN which typically works better and has much easier access with the Fraim Leg.
I canât imagine anyone whoâs heard the 350s would buy a 250.
More prudent to bite the bullet or save up for the end game.
The 350s are fantastic.
@bitsrbits @Peppo62 @naimophile Great to hear the four boxes without power supplies are sounding so good for everyone, it was a big factor in my choice to go with the new gear, the option to do it later maybe ⌠and I was very careful not to demo them at the dealers ![]()
Getting everything packed up for the trip tomorrow ⌠the 350s are so heavy!
Enjoy your system. You will be surprised.
Itâs really really good.
I wonder if the 350sâ advantage over the 250 is only significant if playing very loud or using inefficient speakers. After all, the main technical difference is extra power.
Another âmain technical differenceâ is that there is a separate amplifier for the left and the right channels.
As there is for the 250. But, youâre right in as far as the 350s have separate power supplies.
