I’m thinking seriously about replacing my 300DR with a pair of 350s. Am I correct in thinking that the existing SL din to xlr mono leads will also be compatible with the new 350 mono configuration?
No. the new NAPs use balanced XLR inputs as opposed to the single ended ones used on the NAP300/500.
If you’re using an older generation pre-amp then you’ll need the following cables:
Lead Assembly, Legacy Preamp DIN to New Classic PA XLR, Left Channel, 4 pin DIN to XLR 00-010-0244
Lead Assembly, Legacy Preamp DIN to New Classic PA XLR, Right Channel, 4 pin DIN to XLR 00-010-0244
(2 Unique Cables needed)
Ok thanks Richard.
If the 333 is anything like the NDX2 it will function perfectly as a high quality transport, with analogue out disabled.
I recall on another thread naim said a transport only box wouldn’t really be any cheaper since it would be a 333/NDX2 minus 1 PCB and all costs are absorbed in R&D etc.
And make it CB so it matches the Nait 50.
Thanks Richard,
One more question.
Can the 300px be added the NDX2 like a XPS2?
EDIT: answered by Jason in the video linked above, the NDX2 can accept the new 300px.
.sjb
Well you can cut the ND5XS2 in half then which starts cheaper and contains practically the same streaming part… A shoebox case should also be a tad cheaper than the full width. Plus (and more importantly), I only have half a Fraimlite shelf available for future upgrades.
And the transformer will be a lot smaller.
Thanks for the reply.
Would there be any way of using the new amps active with say SL2’s, DBL’s or 808’s?
Could you use a new 250 on each channel? For example 2x new 250. Or is there any way to use two pairs of new 350’s?
Thanks Richard.
I’m guessing these will be a special order from Naim. I’ve had a look but can’t see a price anywhere. Could you point me at it please?
On Signals website
7. Lead Assembly, Legacy Preamp DIN to New Classic PA XLR, Left Channel, 4 pin DIN to XLR 00-010-0244
Price: $299.00 €299.00 £259.00
Price: $299.00 €299.00 £259.00 (2 Unique Cables needed)
Yes, it should be possible with the appropriate leads unless they cause instability of some kind when used on the SNAXO - best asked of Naim here.
Perfect, thanks.
Thanks again, if you were using one of the new pre amps or pre amp streamer you’d be able to use two new 250’s ??? One on the left channel and one on the right, is that correct but you wouldn’t be able to go any further as in you wouldn’t be able to active three way.
Amazing interview and insights with the legendary Jason Gould!
Maybe I should approach my dealer to demo both NSC222 and NSS333 against my ND5XS2 + nDAC setup… or maybe I really shouldn’t
Yes, suspicion and mistrust certainly seem to be your motto…
A year ago I got hauled over the coals by the diehards on the forum for suggesting that the then classic range was very old and in need of a revamp. What a difference now, I dont see those same head in the sand people praising Niam for releasing new equipment to remain competitive in the now fast changing stereo industry.
The mentality was if it aint broke dont fix it, reminded me of the british motorcylce industry in the 60’s and we all know what happened to BSA, Norton and Triumph.
Good on Naim, very impressive.
You could probably go 3 way active as you only need one output to the PS on the SNAXO and then the SNAXO will provide the required outputs.
Passive, you are restricted by the number of pre-outs - one out (pair of XLRs) balanced and one single-ended on RCA Phonos.
Would love to hear the NSS333 vs NDS/555DR.
