TIDAL App Issues
I am trying to play from the Tidal to my Naim devices, but they aren’t showing in the list of available devices in Tidal. From within the NAIM app, I can select Tidal and play from my playlists but I can’t access all the recommended music selections from there, I have to go into the Titdal App.
Within the App, I play a track and then go to select devices in the top right and SONOS products are shown, but not my naim products like they are in Spotify?
Mike
The Tidal Connect update isn’t released yet by Naim, so that’s why your Naim components don’t show up but the Sonos ones do.
Ahhhhhh - Thank you
And pre-empting your next question, it will be released when it’s ready.
:joy:
My ND5 XS2 shows in the Tidal app as a Chromecast device. Maybe make sure you haven’t disabled the Chromecast input in the Naim app?
How do I enable Chromecast in the naim app? I have Mu-So Gen 1 and a 272
Ah, you didn’t mention in your opening post what Naim devices you had. I don’t think either of them have Chromecast built in.
Ah. Might not get Tidal Connect either, see quote below, I don’t know if that means Connect is for “new platform” only.
quote
“Also to put legacy streamer customers minds at rest, we are doing updates on the Naim native solution to ensure it has as many new TIDAL features as possible and the products are using the very latest API’s exposed by TIDAL.”
And for what it’s worth I just checked the Naim app and unlike Spotify, Airplay etc which can be disabled in the app there’s no such option for the Chromecast built in.
There is for me, NDX2
How odd, I wonder why it isn’t there for the ND5 XS2.
Hmmm. In my Input Settings, on Android, it is:
Bluetooth >
Airplay >
Chromecast built-in >
Spotify >
TIDAL >
Servers >
And tapping Chromecast, there is a checkbox to enable/disable it
Android here as well but all I see on the Chromecast input is this, nothing to disable the input
I can check, but I suspect it’s due to the ND5 XS2’s lack of input button - everything is done via the App.
Looks completely different here on NDX2 :slight_smile: I also don’t understand why you see the IP Address and Timezone and Share Usage Data at the same time, these are not Chromecast settings.
Here is mine after tapping Settings > Input Settings > Chromecast built-in:
Is your app up to date? Should be 2.21.0 in Settings > About.
Same as I have
Maybe it is like Clare wrote, but IMHO it is odd that non-Chromecast settings are leaking through in the user interface.
As an NDX2 user, I appreciate the option to make space in the app for inputs that I am actually using (and avoiding a second page of inputs). IIRC this was a frequently requested feature that I suppose would be just as valuable when using the app with an ND5XS2 :slight_smile:
So I’m assuming this is a bug in the app as far as ND5 XS2 users are concerned?
