Thinking of trading in my current system for a new nsc222 and nap250 (keeping my ae509s). Switching 5 boxes for two and getting the punchy new naim sound.
Be interested to know what folks think.
– nac282 pre-amp + hicap
– ndx2 streamer
– nap200 dr amp
– napsc2 power supply
If reducing box count is your goal it makes sense. Not sure sound would be markedly better. Your listed existing system has ‘napsc’ twice- do you mean NAPSC and HiCap?
nap250dr is my next step – but feels like I’m building redundancy into my system…and the new 250 isn’t compatible with it. I agree – a home audition would be good.
Just for the sake of it, I’d also be curious to compare the pre-amp section of the NSC222 and the 282 keeping the NDX2 as a source. I don’t think many have done that so far.
Apart from the change from 200 to NC250, in my listening experience it will be a sideways move at best, and unless you add the 300 power supply will not sound as good as you have in purely HiFi terms (clarity for example).
You may or may not like the subtle shift in sound signature. It’s noticeable…
never heard anyone say a 282 is not punchy, id keep what you have and buy a nap 300 but…if you wanna reduce boxes and go backwards on quality then thats different, we all have to live with this stuff
I’m probably not alone in feeling a bit ‘at sea’ and confused with options going forwards, especially as I’ve bought and added to or upgraded Naim stuff for over 30 years.
I probably made a mistake buying a SupercapDR last year for the NAC 282 given a long game plan of ultimately upgrading to a NAC 252 as I’ve never quite felt happy with the NAC 282 I got 5-6 years ago.
While I may be able to get a used NAC 252 I hadn’t anticipated that within months of getting the Supercap DR that the Classic range which was completely compatible with my older olive NAP 250s/HICAPs would end up beings discontinued with superficially at least loss of compatibility with the Supercap DR which was hardly an inexpensive component.
So, I think if I was in your position, I’d also be looking at alternatives from other manufacturers as well if the intent was to reduce the box count or look for upgrades while getting rid of the existing system.
A personal thing, but I don’t like the aesthetics of the new kit as much as the older kit either, especially if I was looking to incorporate old and new components, though if I got rid of olive/classic stuff I think the new stuff would probably work visually together, not seen it in the flesh so can’t say with certainty.
