Uniti Core Resetting
This is only my assumption but I think that a bluetooth connection is used during the initial pairing of a mobile device with a new Uniti Core.
It is possible that the mobile device transfers primary local network ethernet configuration data to Uniti Core via bluetooth.
It’s interesting but if you switch off bluetooth on the mobile device you are not able to find and configure a new Uniti Core device.
But I should admit that stwitching off bluetooth on Naim App didn’t solve the problem. Spontaneous reboots became more rare but did not stop entirely.
Just the usual ‘Restart’ after the update was applied, which I believe is advised after any firmware update on the Core. Nothing else.
As I’ve previously said, the update totally fixed the issue for me, not one blip since (fingers crossed!)….One of the rare instances of a software update, of any OS kind, directly nailing an issue.
You’ve confirmed your Core is on 2.5.6 ?
I’m surprised you are still having the issue if so, if indeed it was the very same issue cause….
If it keeps exhibiting the issue, and you have tried a number of remedies to solve, you will perhaps have to start taking up with Naim Support….
There seems to a couple of other threads at present possibly suggesting a bug issue with the Naim App…I don’t have any direct experience, but I do suspect there’s something slight around Bluetooth….as I often get the Bluetooth disconnection warning icon in the App when I put a device into Standby, which is irrelevant and unnecessary really, as I’ve put the device into Standby…!
SC
No really, the Core does not have Bluetooth connectivity at all. So whatever you are seeing is nothing to do with that. Also you never have to pair a Core with a new device. I don’t think you understand how the Core works.
This is related to the Focal Bathys headphones. Unlike Naim units, the app does control the Bathys with Bluetooth and the warning is just the app telling you that it doesn’t have a Bluetooth connection to anything. Whether you have any Focal Bathys set up or not is totally irrelevant. You don’t need to put a Naim device into standby to see this - you can just go to the Rooms screen at any time. When we discussed this annoying and unnecessary warning message during beta testing of the app, we were told that there is a delay in the Apple device telling the app whether Bluetooth is on or not, so you get the warning. It goes away on its own if you leave it alone and it’s about Bluetooth being on in the Apple device, not any Naim or indeed Focal device.
I do actually have Bathys…but as you point out, it seems irrelevant if you do or do not…
Yes, I knew the iOS was slightly slow re Bluetooth info, so I guess this makes sense re what is happening in the App – makes sense now that you’ve pointed this out…….though I do think, with a bit of a tweak, the App could just pause and wait until it flashed up the icon and thus give it more relevance when it does do so….
SC
Ok the final fix was a firmware update. App developers are denying they did anything that would have caused the firmware to be updated. But the app was updated in Mid-November and that’s when my trouble started. If it wasn’t the App then why did a bunch of Uniti Cores all the sudden require a firmware update? I know what my conclusion is feel free to draw your own. Thank you for all your help, it was here that I found out what was wrong first.
A very dangerous response that may need a Public Inquiry.
I think everyone already knows that this was caused by a Rovi metadata lookup change which meant that many metadata tasks were queued by the Core and occasionally it needed restarting to get them all back in order. This was interpreted by some people as the Core “waking up”, which it wasn’t of course.
It was nothing to do with the app anyway.
A TIP in advance: Do not listen to music with the Uniti Core via the SPDIF BNC socket, the Uniti Core sounds much better when it transmits the music via LAN cable (preferably using a Netswitch English Electric SW8) to a streamer or streaming bridge. In my case, the LUMIN U1 Mini receives the data from the Uniti Core. Then the Uniti Core sounds a class better than via the BNC socket. When I used this, there were constant dropouts in the music playback from the Uniti Core.
Regarding the far too many software problems with the NAIM UNITI CORE: I’ve had the device for two years, it sounds very good and I’m happy with it. But the software is a disaster: When ripping, it does NOT find 60 to 70 percent of the CD covers. Even with a CD from the NAIM label.
You can’t select individual tracks when ripping, and you can’t delete individual tracks after ripping, only the WHOLE CD. Unbelievably bad! I have complained about this in emails to Naim and the importer in 2022: NO reply. Until today.
Even worse: Imported music files cannot be edited. And NOT delete them. It’s a tragedy. I have also complained about this in emails to Naim, no response. The software has NOT been improved.
NAIM should only build amplifiers WITHOUT software, they can do that. They can’t do complicated devices with software. And they NEVER will, let alone provide customer service on software issues. They don’t even read this forum, if they did they would know how bad their software is. I will never buy another NAIM device. This company has disqualified itself as a custo
This company has disqualified itself in a customer-hostile way.
You should read the FAQ about the Core on the forum here.
You can edit and delete imported music files using a PC or Mac. This is all explained at length in Naim’s own support area and in the Forum FAQs.
Regarding the art work on rips, there has been a problem for sometime because Rovi made a change to their metadata base but this was resolved by Naim with the recent Core firmware update - you should have 2.5.6 now.
Naim technical support don’t usually reply to emails asking for feature changes. But they do usually reply to requests for assistance. You have to email support@naimaudio.com
Dear Mr. David Hendon. Thank you for your kind reply. You wrote: I could edit and/or delete imported music files via PC or Mac. I have tried x times and it has never worked. With the app/software Evertag on my iPadPro and on my MacbookPro.
Which software works for editing/deleting? I don’t know any other. Please let me know which one works. My Uniti Core is of course updated to firmware 2.5.6. What else?
You also sent me a link to the Naim community, where I am a registered member and have read all about Naim Uniti Core. I clicked on your community link and read it. Result: Nowhere did I find a single sentence about how and with which software you can edit and delete imported music files.
Are you a joker, or were you just mistaken?
I did send my reply to support of naim audio.
My heartfelt request: Help me while I’m still alive.
Dibus480710,
You are not alone, i also think Naim is very weak regarding SOFTWARE.
I suspended an audition of 222-300-252; i am not my spending my money on products that have “fragile” SOFTWARE and badly supported.
I need to finish ripping my CDs before i get rid of the Core. It will take me some months, i can’t rip more than 2 consecutive CDs without a full reset / restart of the core, which is annoying. I am told that i should send the unit to the UK…not in the mood for this,
Good luck
Rui Marques
Dear Rui.
Thank you for your encouragement. I’m not sending the Uniti Core to Naim either. They can’t improve anything. Only via firmware update. And that doesn’t work either. Dilettantes.
What is a 222-300-252?
With best wishes from Dirk
Von meinem iPadPro gesendet
Hi Dibus480710,
NewClassic 222-300-250.
I am told that my Core probably has a hardware issue.
I don’t believe it, sometimes after 15, 30, 40 minutes it starts to rip the CD.
This is not hardware but software related.
Rui
Basically you can use any software, so there is no need to specify anything in particular.
To delete a file you just look on your home network and the Core appears as a hard disc with two folders - Music and Downloads. You can’t edit the Music folder because this is locked and you have to use the Naim app to edit that. But you can do whatever you like in the Downloads folder. So if you want to delete a downloaded file, you just delete it, like any file. Which software you use to edit the metadata depends on what operating system you are using.
But if you can’t see the Core on your network, then no editing software will work. So that’s your first problem to solve.
There are many people, thousands maybe, who use the Core and the software works for them. But your Core apparently doesn’t work, so it probably has a hardware fault. So I suggest take it back to your dealer for exchange or repair.
The Uniti Core is actually even worse than previously described. Since I’ve had it, it doesn’t eject the CD after ripping, although this is exactly what the manual says. An enquiry to Naim remained unanswered.
Today I discovered the following software defect: I have several different versions of some albums (release years or CXRDs or hybrid SACDs). In this case three have already been ripped, all 3 I have given different name suffixes so the software and I can tell them apart. Now I have ripped a 4th version of the exact same album. Consequence: the Uniti Core software has overwritten one of the specially labelled/edited versions of the album without asking when ripping, thus deleting one of the older versions.
