Hugo TT just died. Thought I was done but may be back here shortly.
Ah didnāt know you could do that with tube amps, thatās great, must have a listen to one sometime.
Now Iām liking whatās to the left of that photo
This year has been expensive, I bought a brand new linn lp 12 majik with the koil cartridge, had a lingo 4 fitted then bought a pretty solid steel rack to put it on, bought an audio quest water interconnect for the phono stage to pre then just bought a spanking brand new naim nac 282. next year ill get a supercap and a promotion hopefully im a single guy with no kids
Yikes, what happened?
I went to use it and it didnāt work. No sound. No lights on the display or center except for one white light that flashes when itās plugged in. I assume itās the battery.
hopefully replaceable?
We will see. In the meantime Iām surprised how adept the Pulsemini is with the LDA linear power supply.
As they say, A sucker is born every minute. I just pre-ordered an Eversolo DMP-A8.
Looks interesting as it has HDMI ARC for the TV, you can add an SSD drive, and is supposed to hit above itās weight.
It would be a secondary source for background music/exploring new music and there is a 30 Day Return Policy so why not?
nVidia Shield Pro video streamer to replace my old Denon DBT-3313UD BluRay transport.
My ripped 4K ATMOS MKVs finally stream like they should and my back library of 800 DVD rips look crystal clear and smooth. They were unwatchably bad on the Amazon Fire 4K box.
Had exactly the same with my Hugo and it was indeed the battery in my case. Hope you get it sorted soon.
If itās old (out of warranty) then you may be able to disconnect the battery internally as you can on the mojo and run it that way? Iāve not opened up a Hugo but the mojo is really simple as battery on flying leads with a push fit connector to board.
That looks very interesting, not heard of Eversolo before but just had a quick skim over the blurb on their website and it has a lot of functionality packed in there, should keep you quiet for a while Looks well made too, and has a nice clean fascia, I like the screen in the middle.
Will be interested in hearing what you think of it.
Let us know how it turns out.
Just ordered a mint demo 555dr power supply to add to my single powered nd555.
Bought blind as we often have to do in the USA
Blind faith
Yep blind faith here in North America. Luckily no issues at all.
A friend of mine uses seven of these in his hi-fi system and each one has made a difference, so it should be fineš
Why is that?
Made a lot of blind purchases- all Naim except for speakers (kudos)
No regrets so far
Iāve heard your system is sounding mighty fine according to our Scotch drinking friend lol
