What was the last bit of gear you bought in 2025?
Rega P10 / Apheta3 / Aria MK3.
Okay. So, that’s the outcome. Nicely done … :+1:
Congrats.
Wishing you lots of happy listening.
R
Easier said than done, I can’t add another box as there’s no room for it.
Yes, agreed, I think the App is very straightforward.
Maybe needs returning?
Nice, what finish is the plinth?
DG…
@ratrat Many thanks! Yes, the P10 won the day. I’ll post more in the other thread later.
@DiggyGun Its the Polaris Grey finish.
Congrats on your purchase of the NDac. It is a very good combination with ND5XS2. There is a separate thread about this(Click here), in which various BNC cables are also discussed (use the search function ‘BNC’ ‘in this topic’ to easily find the posts). DC1 is certainly a good option, but not very cheap. I myself use a Neotech NEVD-1001 with Furutech BNC plugs between ND5XS2 and NDac. It costs only about half as much as the DC1 and I am satisfied with it. Enjoy your NDac!
Sure the DC1 is an excellent cable, a few of us are using a Mark Grant which seems to perform well and it considerably cheaper.
Just another option to maybe consider.
New custom shelf just arrived to swap out chopping block.
Whole GR2 looking very stealth now.
Put in a cheeky offer for some ethernet woowoo. It’s staying!
Stack Audio ‘SmoothLan’.
Same job as EE1?
I think the same claims. There’s a few ‘B Stock’ on the ‘bay. I offered £80 below new rrp, which was accepted.
It arrived ‘as new’ so probably a customer return.
I’m not sure these count for the thread as they cost under £5 from a certain well known online retailer beginning with a capital A. However, they have been revolutionary in helping to keep my cables separated and, in particular, my heavy mains cables at the right height to avoid the IEC inlets on my units being dragged down.
Unlike some of these products with 3M type sticky pads, they do not take the paint off walls or skirting boards if you remove them. If you decide to get some, my advice is to follow the instructions and leave them in place for 12-24 hours before attaching cables to them.
@Damien0 these are so good, they are ‘nearly’ in the same league as the yellow and blue dusters…I’ve therefore asked my M&A team to do some due diligence with a view to buying the company in honour of Victor Kiam :+1:
Unlike normal zip ties, could the clamp be opened again to release the cable if needed or do they require cutting off?
Those look quite good, I’m going to get some for running mains cables away from signal cables I think
Btw have you tried standard mains cables that came with your nap350?
The reason I’m asking is because I tried some of the chord purple power cables at one point and found the standard ones better
:joy: :joy: :rofl:
I have a strong feeling that you are my sense of humour doppelganger :rofl:
Yep, I did the same bought two!
No idea how it works, but work it does😃
Good question and yes they do allow this! Pretty awesome product. You just pull the cord towards you away from the clip and it unlatches :+1:
I haven’t yet; but I will definitely give it a try tomorrow based on your experience. Especially before I store the boxes away. I also plan to give the Naim XLR cables a try vs the Linn ones I am currently using :+1:
