can you tell me how much it can cost to run the service for the 62-hicap-250?
Your Naim distributor can give you an indication as to service costs.
It may help
There is also the Naim olive thread.
Whilst I was waiting for my BTE custom built passive pre I got a Khozmo passive on approval to try out with my Quad QSP. Passive pre’s are a bit of a minefield ideally a power amp with a low impedance input of 10k like mine should have a pre with at least 5k impedance output but you can go up to 10k if you have short leads of 50cm or less with very low capitance or so I thought.
A shunt attenuator like the Khozmo can affect impedance and so with an amp like mine cause frequency roll off in this case it caused thickening of the lower midrange/upper bass and also another effect is that you’ll need the whole dial to get a decent volume.
Although the Tisbury mini that also has 10k has no such problems and sounds incredibly good for the price. I added a 50cm Neotech NPOCC cable between the Tisbury and it had a more positive effect than any cable I’ve tried before.
Can’t wait to get my BTE which has a tdk mecahinical pot and has been put together to work with a low input amp like mine.
That’s a wonderful sight to behold - so good Naim did a brochure that folded out into a poster of that very shot - the inside of a NAP250.
However, those caps look like originals…
And what about the transformer? Is the 400VA or 500VA?
I don’t know.
As we continue to adjust to a new norm, I unboxed my old UQ and bought a pair of Totem Mites to go along with it in my makeshift home office. Speakers are still running in, but the sound coming through at low volumes is really fantastic. Great little inexpensive setup.
Would you sell the gear if it was 400 or retain it if it was 500 va ?
I would keep it anyway.
Here’s the bolt-together 250 inside.
Yellow caps and very different layout. This had transistors mounted on the back.
No more thumping switch on and off, no more infernal buzzing transformer and I get to play with some room correction software.
Not a bit of gear as such, but hopefully a cheapish upgrade - two sheets of 7.5mm tempered glass under which will sit Naim cups and balls.
One shelf will go under the fruitbox, the other underneath an Oppo 205.
Will be interested to hear the report on the effect on the sound as I have wondered about similar.
After you are done and satisfied…a few clear photos will be nice to see…
I have 10 mm tempered glass…was wondering how to place the Naim cups and balls.
Request you to try these on the source first to see if these impact the source more than the amplification.
Astell&Kern Kann Cube DAP, the show me your headphones thread is to blame…new headphones and DAP in last week.
These purchase allow harmony with the wife whilst working from home.
Raspberry Pi4 running Bubble UPnP Server (installed via GentooPlayer) to add Qobuz in hi-res and transcoding to WAV to my Uniti 1.
Installed in a black passive heatsink.
Sounds fabulous!
Front balls 415mm apart, 20mm back from the front.
Rear in the middle
My new (second hand) Allnic T2000 integrated tube amplifier with upgraded KT150 tubes.
At 40kg it’s a bit of a beast.
I’m currently just testing it in a small second system comprising of an old Technics SL-XP490 CD walkman player and my old MK1 Linn Index speakers on original Linn Sara stands.
My first impressions listening to Bruce Springsteen - Western Stars CD is that it is a very enjoyable experience.
I would also say that this is the first Amplifier I’ve had that has managed to make my Linn Index MK1 speakers sound really good.
