Thank you to all for the unsought advice. People clearly know next to nothing about the Rolex Oyster case. I have been doing this every so often for a number of years, and no hot water or dishwasher powder have got inside.
If itâs a Milgaus then itâs only 100m water resistant. Spraying it with water at high pressure could exceed that as the normal test is static water pressure.
I speak personally, but I suspect the sentiment, even if expressed in a way that wasnât appreciated, is shared by most, if not all of the posts you refer to; I truly hope your watch is fine.
I was surprised to read of your cleaning method, did a bit of reading and then thought long and hard before posting about it. I am not a fan of unsolicited advice either, but made an exception in the hope that informed decisions or revisiting past decisions, might result. If youâre happy that no damage is possible, and have tried it before, then thatâs very obviously fair enough!
Maybe a call to the AD, just to double check their advice, might be worth it, just in case. I mean nothing but goodwill by this post as well as my others
Who would have thought that the ultimate show us your willy thread would yield such comedy gold? That one is up there with @Christopher_M âs excellent Mielegauss quip earlier.
The design is robust, the question is about whether it should be challenged in a dishwasher. The chemicals are agressive and hot.
We couod always ask Rolex as the owner of the design as to whether theyâd recommend this method.
