Confused now. How are you connecting you TT to Aux2?
That makes sense. I have found that keeping it a long way from anything else in the hifi is a good plan, though it does need a bit of air for cooling.
Ah ok. I can place the napsc at the back of the cabinet on the floor and no cables will be down there. Can it be placed on its side?
RCA cable goes into phono stage and then another RCA cable goes from phono stage to the RCA inputs on 282
That’s absolutely fine, don’t worry about it. But try to arrange your cables so that the Snaic, which carries power, is kept away from the sensitive signal leads.
Aah, I see. I didn’t realise that Aux2 had RCA connections.
Thanks for clearing that up. I’ve only owned an 82 not a 282.
Right, so if I place the Napsc out of sight and out of the way of sensitive cables it should be ok even if rested on its side.
My only concern is how do I pair a new Narcom 5 remote with the 282? Anyone know please?
You don’t need to pair it. Just press ‘pre’ and it will work.
I’ve never tried, but it should be fine. My Naim dealer once installed a Superuniti on its side for a customer who had limited space, and he reckoned it wasn’t a problem.
In regards to the speakers is Ch1 Left for the speaker on my left when facing the unit? And Ch2 Right for speaker on my right?So the speaker cables cris cross on back of the unit?
After much tweaking here’s the final set up. Cables sorted so they do not touch. Napsc on its side on the floor. Brawns at the bottom and brains at the top. TT away from it all.
Very nicely done👍🏼
I went to play some music through Spotify on my NDX and I was getting no sound. I went to the device and pressed the input button about 5 times. Each time it changed the input. On the last press it just came up with this error screen and the music started working. Any idea what it means?
I remember there was a thread on here on how to “upgrde/improve” the NDX so that it can play Radio Paradise and so in but can’t find it. Anyone can point me to it please?
VTuner may be what you are looking for?
Are you talking about the internet radio server setup
Or workarounds using minim server, start reading here
Me again! I have just pulled the plug and traded in my NDX and Nova for a new NDX2.
A couple of questions please:
- The manual shows that the contents should include a BNC to RCA adaptor. Is that the case because there isnt one in the box?
- What kind of cable do I need to connect the NDX2 to the 282 for system automation? I am hoping to be able to control the system through the app rather than have a remote hangin about.
