New firmware update
It was an attempt at a joke, as the Firmware updates says it’s improved the sudden reboot. One would hope it has fixed the sudden reboots, not improved the reboots…
Perhaps they added new boot animations so that there is something fun to look at while the machine reboots. I’m thinking pacman eating small Naim logos, or Q*bert jumping over the peaks in a waveform.
So I’ve updated my Nova to 3.5.1 and fingers crossed it works. Tbh the random reboots weren’t that frequent and a minor inconvenience. It’s more disconcerting not knowing when it may happen and that makes the listening experience less relaxing than it would otherwise be.
I never had reboots but have installed upgrade so that BBC radio channels stop cutting out
I hadn’t realised that had been a problem with BBC radio.
First impression after 4 hours of listening 3.5.1:
“Cleaner”, more detailed sound with tighter bass. Do I just imagine this or does anyone else have the same impression?
Is this a beta version folks are accessing?
No - just found it on app this morning. I am not in beta group
No. I am not part of any Beta group.
The new firmware showed up this morning, when I checked by a coincidence.
Details are here;
Do note that this release is only for new Uniti systems. An update for new platform network players will follow shortly.
There are almost certainly no changes to the audio processor in this upgrade, so any perceived difference in sound would likely be imagined. It’s difficult to say however if the upgrade process could have changed or reset any existing settings that may influence the perceived sound, i had this happen in the past and also wasn’t sure what the source of the change was.
Good news …hope it’s not psychological feelings
I was not sure myself if this was something that I imagined or not.
However the more I listen, the more I am becoming convinced that the sound has improved as previously stated.
I just do not want to stop listening as it sounds so good.
You need more days to be sure if it did better for you
So the update went fine, but the powering off the network was a disaster, after allot of reboots of the router, i finally gave up reset, went on the school run all working now.
Interesting the last song I played was The Beatles with iPeng (more radio listening today) went hitting play it was definitely more dynamic from the first note.
More listening later…
You are of course right.
Let’s hope that my first impression was correct.
I honestly did not expect any changes and I was not trying to find any.
It just struck me how good it sounded.
Dynamic. Yes. That’s the word I should have used!:+1:
Same here. Kudos to Naim
My word this sounds very good.
Unfortunately I’m getting stuttering with 24/192 Qobuz purchases played via Roon or directly via the app.
@Richard.Dane
Would there be any reason why I wouldn’t see this update in NZ? It doesn’t come up when I go to settings and says 3.5.0 is my installed version. ???
