@paulbysea Are they Linn Skeets under your Speakers? If so, how you finding them?
Thank you. They are Track Audio stands which include Track Audio isolation feet. The shoes are also Track Audio. I use the delrin insert models as I have wooden floors. I’ve tried a few stands and found these to be among the very best, if not the best speaker stands I’ve ever owned.
Thanks Ants👍
Hi, yes they are.
Funny skeet are mentioned. I find them indispensable. I’ve had a set for nearly 30 years and although I don’t use them under anything, they are great as a positioning shoe. They slide very easily over wooden floors allowing fine positioning of speakers ot racks before swapping in a preferred spike shoe. They are incredibly useful.
They are skeets.
Thanks👍
Ants… Did the shoes come with the stands, or did you have to purchase them separately?
They were purchase separately.
Slight issue with electrics into cabin so been forced to deploy the Sony Boombox.
Some pacy sounds via Spotify and even some Naim style backlights.
have you asked your dealer if they can get Naim to make you a longer powerline?
Check this link:
Apparently someone asked their dealer about making a longer powerline.
Yea a longer one, im sure they could probs sort something for you. worth an ask init
I can get over it and change the plugging order on the block. It’s all working pretty well.
oh yea your right, a few posts down.
