The reason also why you tried is perhaps because you don’t use an audiophile rack anymore ?
i tried them on my nova on isoblue stand - they made it sound forced and pinched
Pic from furutech
Hi guys …side track abit , need some advice , has anyone has experience with this connector ? I am keen or rather must change my powerline EU to US … thanks
Or any to recommend from furutech under the same league ? Thanks
I have them under my Ear 912. Working very well. But under the Ear amp, they give less grip and snap. Then I put them under my Melco.
Have not tried under Nds, but there’s already a good isolation with brass springs.
If you are looking for info on Furutech, this would be a good place to start:
Furutech Discussion - Hi-Fi Corner - Naim Audio - Community
Short answer, yes the FI-50 NCR R is a top notch connector. Though don’t recall any here using one on a powerline. I have a number of these connectors currently in use on other cords (7), swapping out the stock US PL male ends (look to be the entry level Wattgate male plug) is something I’m still thinking about trying at some point.
@daren_p hi Daren , thank for your reply . 2 of my powerline comes with EU connectors , so I have to change them so I can use them , they are spare powerlines for me but do not want to waste them , i can pluck into my other equipments
If I had a spare PowerLine I’d likely swap it as well. Let us know how it works out
Sure thing . I will enquire tomorrow and check on stock availability and price too powerline is one of the best power cord I had ever owned , so not gonna let it go to waste
I’m getting fed up of how tidy everyone’s lounge is compared to mine. How about a ‘cable dressing pics 2024’ thread to make me feel better???
Your system is identical to my ofice system, and we seem to agree on the distance to the back wall.
Like you I am very pleased with the sound.
This thread might be worth a browse…
@daren_p @marcusman hi guys… had contacted furutech on the connectors , bringing it down tomorrow for the change , however , maybe need to add mini spades inside according to him and if all goes well , can be done on the spot, if not will take a few days for him .sure this is an expensive connectors but I believe the end products will serve me very well , shall update when I get it hook up on the changes in brings to my kits
Looks great. Simplistic and elegant
I had a pair of 52se about twenty years ago and loved them. How quickly time passes
Here is the proof that your TV does spy on you, the light spilling into the room has caught the outline of the spy watching what’s going on.
These are Heritage Specials … Just tremendous sounding.
