Vtuner BBC radio issue - work-around
There currently appears to be an issue with BBC channels and Vtuner on Naim streaming devices. Here is a temporary work around for UK Naim customers to access BBC stations through the Naim app.
  1. Select the desired streamer via the Naim application
  2. Select the Internet radio icon at the top of the app
  3. Select the “Naim’s Choice” choice
  4. You will find at the bottom of this folder BBC radio 1-6 which will all work.
Please use this as a work around until the regular service is restored.
Alternatively, for those outside the UK, you could try using BBC Sounds and then casting to your Naim device.
