Gordon
November 27, 2023, 7:59pm
1
Just ordered the WiiM after reading and listening to the reviews. Does anyone already have one?
I love streaming for many reasons but a big one is it allows me to listen to the Community’s Best of , and other recommendations.
Hi, have you read the existing thread on the Wiim streamers? Loads of opinions and views. Worth a look.
I have been looking to find a good solution to add additioal streaming capability to my NDX and Superunit. While I was very happy with the integration with Tidal, I really wanted to integrate to Qobuz and if possible to Amazon HD.
There is a lot of talk on the internet about the WiiM Pro - so I thought I would try it. Ordered a unit from Amazon (on the basis that if it didnt work I could send it back) and installed the unit yesterday.
The unit itself is a compact black plastic box - of good qu…
has anyone now got or tried a wiim pro and what did you find?
thanks
Does anyone have experienced Wiim mini?
I have been using N272 + 250DR for over 2 years. And, I feel tired of NAC N272 due to its malfunctioning with Tidal.
Possibly, it could be one option, I hope, to use Wiim mini to stream digital signals into N272’s internal DAC.
Theoretically, this should not deteriorate the overall quality of sound.
What is your opinion?
I have recently hooked my old Unitiqute 1 (original, never upgraded version) up in the office, and it really sounds great in the smaller space with a pair of bookshelf Totem’s.
I would like to use Roon (as I do in my main Naim system), to stream Tidal and access my music library. I was wondering if an inexpensive solution would be to hook up a WiiM Pro to the UQ, as it’s a Roon ready device? Not sure if the limitations on the original UQ would be an issue with this, or if it’s even doable as …
They will not read themselves…
(the above are the top 5 results for a search for ‘wiim’)
sjw
December 23, 2023, 8:35pm
4
Has anyone compared the wiim pro plus with an old Sonos connect?
Gordon
December 24, 2023, 4:40am
5
I have both and will be testing my new Wim Pro Plus as soon as I get my speakers out of the shop. I’ll post my comparision or review soon.
system
Closed
February 22, 2024, 4:40am
6
