Hi, is anyone having problems with their App / Tidal / NDS in the last couple of weeks.
I’m having issues where music stops and/or the NDS disappears from the App until I turn it off and on again
I recently upgraded to iOS 15 and I’m not sure if that is the issue, or if Tidal is the issue (I know it was down the other day). DownDetector is showing some issues on Tidal again this evening, but in not sure that would cause the NDS to disappear from the app
I did the NDS upgrade a while ago, so I don’t think that is the issue
I just want to see if other are having issues or if it is just me, it has been very reliable for the last couple of years
How long ago? Did you do the most recent 4.8 update?
Yes it was 4.8 in Sept
It has behaved it’s self until recently
Just bumping this as I still have the problem as well as my Qb also consistently drops from the app
Sounds like we’re having the same problem. Also NDS with 4.8 and only started recently. Radio seems ok but problems with Tidal. Press on the track and nothing happens. Have to close app and reconnect, or switch to radio then back to Tidal. Seems very unstable.
I’m still on IOS 14
Few things to check. Are you running the latest version of the Naim App? (5.23 for Apple iOS devices; 2.23 for Android)
If so, i’d home in on TIDAL itself - try logging out and back in again via the Naim App. Others have reported changing their TIDAL password has helped, too.
Thanks Clare. I’m on 5.23. I’ll try the login and password later and report back.
Hi
I received the following from Duncan at Naim.
I’m three albums in and it seems or be behaving itself,
If so, then it could be the app permissions, and/or the iOS version. We have had a few examples of problems with the Naim app and connectivity. A lot of these can be attributed to the ‘new’ features added by Apple to their iOS firmware.
On your iPhone/iPad, please go to…
Settings > Privacy > Local Network
Check that the Naim App is selected (Green). If the App is already green, please tap to turn off (grey), and then re-tap to turn back on. A new command needs to be sent to the network, and restarting the setting will do this.
Settings > Wi-Fi > Networks
Head to your available Networks and tap on the network you are using, then look for the “Private Address” setting and disable it. Re-join the network when it asks.
After changing these settings, please restart the Naim App, your unit, and your router.
Tidal instructions…
Tidal - Creating a fresh connection to the Tidal Servers.
If you’re having trouble getting Tidal to work properly, please try refreshing the connection to the Tidal servers by following these steps.
We have had a few reports of updated security protocols, blocking the connections to Tidal servers. To check this, go into your main router settings, and ensure that Tidal has the correct permissions to communicate through the built-in firewall.
If you also have antivirus/firewalls on your home network, most likely via a PC/laptop, you may also wish to check that Tidal isn’t blocked there.
You can refresh the connection to the servers by following these steps…
Go to Tidal’s own app, log in, and change your password. Make sure you only use capital letters, lowercase letters and numbers, do not use any special characters (*#@£&%).
Open the Naim app and go to Settings (cog) > Input Settings > Tidal, and then log out of Tidal.
Close the Naim app down, do not just minimise, and then start the Naim app up again.
Navigate back to the Tidal login area - Settings > Input Settings > Tidal, and log in with the updated password.
Try Tidal
If you’re still having issues, it could be because of stored data being corrupted.
To clear old data from the Android version of the Naim app, please go to your phone/tablet settings, and then Apps > Naim App > Storage - And clear the Cache Folder.
To clear old data from an iOS (iPhone/iPad) device, you’ll need to uninstall the app altogether, and then reinstall it.
Doing this will remove stored radio presets and playlists created in the Naim app.
Open the Naim app - Go to Settings > Input Settings > Tidal and log in with new password.
Quick update; only did the first Local Network restart and t’s been fine for the the last 24 hours or so.
Hi, i have the same Problem with my NDX with 4.8 . i have also a unitiqute2 running 4.7 and there are no problems. I have also a bluesound node 1 and you know it … No problems … I’m getting more and more angry with the naim staff by using tidal … There are always troubles and nobody is something doing against this . if they can solve the Problem i guess i will dell all my naim gear … I’m very very angry
Are you on the latest App version?
Otherwise, have you gone through the advice from Naim in Danny’s post above?
Although the advice in my post has helped, it is still not perfect and the NDS still comes up with a Cant Play message and then freezes, or ‘connecting’ message and freeses, needing the NDS to be rebooted, and then it works for a few days. I’m still feeding my ‘issues’ back to Naim, but I haven’t heard anything since I received the advice above.
My wife keeps asking me why we sold the CDS3 as she doesn’t have the inclination to rebook the NDS, close the app etc.
I just wrote to Naim support this morning for same issue type, N272 stop playing and disappear from the app with this message: An other user is connected, disconnect it and try again. I don’t understand why this message as I used N272 only. all were updated, try the previous recommendation and still having issue.
it happening with classical music only (my choices of composer may be? Hope not…)
No problem with Muso 2 at all.
The message I get on my app when trying to connect to the NDS when it freezes is ‘another app connected’ which I think it some sort of connection session between the NDS and the Naim App, and when you this error, it thinks the old session is still live and therefore won’t let you reconnect to it.
My Muso QB is also OK since the changes outlined above.
My friend who uses an Android device to control his NDS doesn’t seem to have any problems
Sorry Richard , your question indicates the real Problem and the Problem is that there is no idea what the Problem can be. Oft course i’ve tried all the things you wrote above. The only thing that i’ve not done is to change tidal password because my password has only characters und numerics. Sorry AS a former IT man i can say this can definitly not be the problem : AS you can find by Google “naim tidal problems” this problem is pending since the update to 4.8 to the streamers with the audivo streaming platin. But the Platine is not the problem because you can find the same problems on the New streaming Plattform. See the guy with the New atom which he bought last month. … Now my question: are there any activities to solve the problem together with tidal ? All the best Fritz
As to how widespread an issue it may be I don’t know - I would expect many more members here to be reporting it - but all I can suggest is that you work on it with Naim support. As for the rest, only Naim could say.
I’ve had similar problems and have gone through all of the above steps. Usually solved eventually by force closing the Naim app and switching inputs to radio, which then brings up on NDX screen ‘Input initialising’ then after about 30 secs works again. It’s not all the time but at least once a day. Bit frustrating. Latest firmware, app etc.
This happens to me as well. N272 with 4.8 and only since 4.8. If I start a tidal playlist using the app and then pause using the remote, restarting with the remote will not always work. If the pause is short, no problem. If the pause is long, it does not start again. Switching to radio and waiting will sort it.
As you can find many people who Reports the Problem with Tidal Since the Update to 4.8 on the streamens ist seems That the Naim Support is sleeping. Many people who have contacted the Support Tell us That the get on answer. Now the Problem is pending since Last September and it Looks like That the naim support has no idea what the Problem can be and therefore they hide in the Castle and ignore all the question for help. If here in the Forum is any guy who is from the Naim companie so please Tell us …… why is this so and are there any activities to solve the Problem together with Tidal ?
Fritz, I’m a bit confused here as Tidal made big changes which is what necessitated the update to 4.8 However, you say you are fine streaming Tidal on 4.7. I can’t help but think that remaining logged in on 4.7 may be causing the issue with the NDX on 4.8. Have you investigated this possibility?
