Speaker Cable for Naim power amplifiers
Naim power amplifiers do not have extra inductance networks in the output. Naim prefer the more elegant solution of allowing the speaker cable to provide the correct inductance and capacitance.
To do so, a minimum of 3.5 metres per channel of NACA4 or NACA5 cable is required – although the optimum length is around 5-10 metres with a maximum recommended length of 20 metres. We find the supplied Naim speaker plugs to be an optimal match for the 4mm sockets we use on our amplifiers.
In addition, the plugs are designed in such a way as to prevent them being accidentally inserted into European mains sockets - hence the warning in your Owner’s Manual
“The Naim loudspeaker connectors supplied are designed to comply with European safety legislation and must be used.”
Cable length for left and right channel should be of exactly equal length – even if one speaker is closer (as is often the case) to the power amplifier.
It is advised that you position the system away from between the speakers, either off to one side of the room or at the opposite end. As such, longer lengths of cable are ideal and will work without significant information loss.
Spare speaker cable should not be coiled – excess cable may be tidied up in a way similar to that employed in the “Jumping Jack” firework. Use cable ties or similar at either end to hold in place. Additional: I would not recommend any particular length for the folds - you can make the folds suitable for hiding but use some sense. You are most likely to end up with one cable needing to be tidied - that to the nearest speaker - giving the distance between the speakers as the amount to be dealt with. Avoid having the doubled (tripled or whatever) too close to either the speaker or the amplifier end of the cable - to give as much flexibility as NACA5 allows for the final run at each end.
Avoid running the cables parallel to mains cables.
Apart from Naim’s own upgrade cable - Super Lumina (3m/channel minimum) - alternative speaker cables cannot be recommended by Naim, however, should you still wish to try them then you should ensure that the cable is low capacitance and of moderate inductance. High capacitance &/or very low inductance cables are to be avoided at all costs and may result in damage to your amplifier.
NACA5 specifications are as follows:
Capacitance: 16pF per metre
Resistance: 9 milliohms per metre
Inductance: 1uH per metre
Minimum length: 3.5 metres per channel
Maximum length: 20 metres per channel (note that longer lengths can be used up to around 25 m but then some small signal loss must be expected)
NACA4 versus NACA5 speaker cable
Banana plugs
Speaker cable length
Naim newby - completely lost on how to get started
NAP250 olive and cable compatibility
Speaker cable. Upgrade?
Which Speakers Cable?
Nap 250 & Chord signature Cable lenght
Nordost loudspeaker cable with naim
SPEAKER CABLE for naim amp
Naim NAC A5 Length
NAIM with QED Supremus speaker cable
Speaker Cables
NDX & SUPERNAIT Thread
Shunyata cables
Are these speaker cable specs safe to use with Nova?
Sorry for another power cable thread: What would be the best choice for an Atom? (Audiquest vs. Chord vs. Isotek)
Naim Atom unity - bi wiring
Speaker cables
Speaker cable lengths
Seaker cable specs
Uniti Star – praise and possible tweaks
Naim nap140
Supernait 3 question
Amplifier Over-Current Condition Detected
Linn k20 speaker cable
Real use case on speaker cable damaging naim amp?
Speaker Cable
NAP 500 and 2.5 M cables from QED Reference XT400
Naca5
Tellurium Q-Black 2 alternatives... (speaker cables)
Atom - Speaker Cable Advice Please
Cable length
Speaker options for 282/250DR
Hms and Naim speaker cable
New Joiner
Nova - Heat control
Help With Speaker Wires
Newbie: Atom + PMC DB1G =?
42.5/140 or Nait 5si/XS
Adding a poweramp to the Nova
Naim 'Hiss' active Vs passive pre
Bass & Treble adjustment
Naca5
Uniti Atom sound quality
Cables chord Vs naca5
Kimber 12TC speaker cables
New naim AMP for custom build speaker
Can short speaker cable lengths damage equipment?
Loudspeaker Cables For SN3
Cable length
System Pics 2023
Naim speaker terminals query
Naim newbie needs hookup help
Litz Speaker cables for Naim
NSC222 and NAP250 noise/humming in Speakers
First time Naim user needing help
Tellurium blue II speaker cable
The Naim New Classic range - Part 1
Which cables please
Uniti Star very hot and not playing out of one speaker
NDX 2 + SN 3 or Nova + 250DR to start? (Update Dec 2020)
Naim nap 300dr
Speaker cable for set up
Ideal length for speaker cable (non-NACA)
Connecting to old speakers
Naim xs3 what speaker cable length?
Speaker spade connectors
Belden 9497 with NAP 180?
Nait50 auto shutdown in 12 minutes
Speaker Cables
Nac a5 length, is there a maximum?
Nait XS3 - Maximum Speaker Cable Run
Dali speaker cable
SN3 Warning Lights And What Actions Required?
Cardas Crosslink 1S vs.....for Nova
Adding a NAP to my Uniti Atom Speaker Cables
LFD Audio cables with CB Naim
That’s silly!
Connecting Naim Nac-N-272 to Another Make Power Amplifier
Nordost speaker cable advise
Confused about my Atom
Uniti Nova has been burning for three months, but it still sounds terrible!
Naim Nova Totem Fires. Wire? Cardas?
Naim Atom + Roon Nucleus
Nap 180 with Threshold SL 10 pre
New Joiner
Speaker cable length NAP300DR
Response from support
Do you need special cables for SN3?
