@Thomas Can you elaborate on your choice of the Taiko server? With thanks.
Initially, I did not want to use a server.
I wanted to use Roon as advised by Roon Labs : a Roon server somewhere on the network and a Roon Endpoint connected to the DAC.
The ND555 is designed that way : the streamer part of the ND555 includes a Roon Endpoint. Therefore one can use whatever server somewhere on the network. The server needs only to be powerful enough to handle the Roon Core.
Taiko Audio has a difference approach.
The Taiko Extrem is a powerful machine that includes both the Roon Server and the Roon Endpoint.
In my opinion, this was nonsense. Butā¦ only fools refuse to change their minds.
How Taiko solved this problem is brilliant!
They implemented the Roon architecture in their own way, quite cleverly.
The result is that āpartā of the server runs the Core, and another āpartā runs the Endpoint. The whole thing is cleverly tweaked at the software level.
Taikoās approach is so good that Roon now outperforms their own software, which is good news as Iām Roon user.
So both the hardware and software are highly optimised in the Taiko Extreme.
I ended up buying a Taiko Exteme, which Iāll use with my new DAC.
That is supposed to a great server and in your system should sound amazing, what size ssd did you go for.
Thanks, @Thomas. I have some more questions for you. @Richard.Dane - can you let @Thomas have my e-mail address please? Thanks!
Is Isoacoustics Gaia 3 weekā¦ @Mahesh
I replaced the original spikes of the Solid Steel SS6 Stands. I initially had doubts whether the Isoacoustics Gaia under Speaker Stands have a similar effect as under floorstanding speakers. But they have. Not night and day but they bring tighter bass and a little more resolution. I like it.
Hi Gazza,
Apparently, the Taiko Extreme is amongst the very best, if not the best. I wonāt be able to confirm that as I wonāt buy another server
But some did, and found the Taiko Extreme rules them all.
Iāll compare it against the network adapter included in the Soulution 760. Again some have already done that test; the Taiko seems to be the best choice.
As for the SSD, the Taiko server doesnāt use SSD drives; theyāre too slow and clearly would be the bottleneck. Instead, they use PCIe modules, which are way faster than SSD and less noisy. Hence the priceā¦
I ordered the server with 16TB storage capacity and the USB Extreme adapter.
Ahh that was itā¦ā¦those modules, should be very specialā¦ā¦plenty of opportunity to tweak with cablesš What a great system you have coming togetherš
Cables, tweaks, ā¦ that wonāt happen
The only thing I enjoy tweaking is my room treatment. Amazing results for little effort. And I like its predictability, which is not the case with cables.
Well, Iāll do some test anywayā¦ Ethernet cables!!!
Iāll try three of them :
- simple Cat.6 U/UTP
- AQ Vodka
- Nordost Valhalla 2
So from really cheap to Ć¼ber expensive
I bought the whole set of Nordost Valhalla 2 cables:
USB, EtherNet, 3x power cords, interconnects and speakers.
For that test, no expectation bias.
It really doesnāt matter which one is going to win.
But Iāll try to match the colour of the cables, the aspect of things matters as well.
@Thomas: Richard D has sent you my e-mail address. If you are agreeable, Iād like to ask a couple more questions offline - with thanks.
Please excuse my āoff topicā question.
I also need to speak with Richard D - offline - how is this done?
Iāve flagged your post, so Richard will see it.
Hi Mahesh - how do you find the addition of the Gaias?
Thank you
Iāve messaged you.
Iād hope itās something special at ā¬24k+ā¦
You can have a look at the Antipodes K50. Considered among the best actually, with the Taiko.
Hi Billy,
Did send you a message, hope I can help.
Thomas
So do I! It was a tad more then that
It should be here in a few weeks.
Build quality looks top notch, look forward to your findings.
